× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Trying to setup Kasa smart plugs and my nighthawk modem kicks off all wifi to my house
Scoves
I have the nighthawk model RAX35.   I just obtained some Kasa Smart WIFI Plug Lite HS103's.  When I try to set them up to my internet so they can be used my wifi goes down.  The Modem disconnects all wifi and will not turn it back on.  I have to unplug the Kasa Smart plug to get it to start my wifi back up.  Something is going on between the modem and the Kasa smart plugs.  I tried working with Kasa but they said it is not on their end.  That it is on the Netgears modem end.   Which stinks for me becuase I am a few months out of warranty to get support.  Which makes it almost cheaper to go out and by a whole new modem instead perhaps not a netgear one at that.   I am wondering before I do all that if anyone has had similar issues and had them resolved?  Or would know why this occurs.  I have set up another brand of smart plug and it works fine along with other wifi items I use but for some reason the kasa ones disagree with my modem.  Thank you for any help.
Firmware version by the way for my modem is v1.0.3.62_1.0.1
Message 1 of 5
Accepted Solutions
Scoves
Re: Trying to setup Kasa smart plugs and my nighthawk modem kicks off all wifi to my house
I solved the issue finally.  I was able to update my firmware and it fixed the issue.
Message 4 of 5
All Replies
CrimpOn
Guru
This question is more likely to get a response from someone who knows about Nighthawk AX routers if posted in the community forum for those products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
I have several KASA 105's connected to my Netgear Orbi WiFi. They were the easiest smart plugs to set up.  I canot think of any reason why connecting a smart plug would cause any WiFi system to shut down.  Since the "complimentary" support period has expired, if no one on the AX forum has a suggestion, I would switch to another brand of smart plug.
Message 2 of 5
Guru
Please visit and post about this over in the Nighthawk RAX forum:
Thank you.
Message 3 of 5
Scoves
Message 4 of 5
Guru
Please mark your thread as solved so others will know. Be sure to post in the RAX forum for any future help and information.
Enjoy.
Message 5 of 5
Discussion stats
  • 4 replies
  • 2255 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
