- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Upgraded from WNR3500v1 to RAX50 - old Windows 7 work laptop will not connect SOLVED
- Mark as New
- Bookmark
- Subscribe
- Permalink
After reading about the web server vulnerability in older NETGEAR routers, including my WNR3500v1
https://www.zdnet.com/article/unpatched-vulnerability-identified-in-79-netgear-router-models/
I decided to get an upgrade and settled on the RAX50. Everything went along swimmingly (Dell Inspirion W10, Powerspec W10, iPhones, Linux boxes) until I got to my work laptop (as I've been working from home even before the COVID HOAX) - Dell Precision 7510 with Windows 7. It would not connect to the new router, and would not even see the router with SSID broadcast enabled.
I finally found that disabling the new "AX/OFDM" feature allowed the laptop to see the router - leaving the router in Smart Connect 2.5/5Ghz mode allowe connection with and without SSID broadcast. All happy now.
The work laptop is about six months overdue for replacement (caught in the COVID HOAX VENDOR SNAFU) - I'm assuming newer hardware and W10 will work with the AX feature.
Some other details:
* I like Access Control to avoid having anything I don't know about connecting to my wireless. However, with the RAX50 Access Control is applied to WIRED connections as well as WIRELESS connections - so you have to approve all of your connected devices. A little more trouble - I'd like a choice in an environment where physical access to my wires is limited.
* There the possibility of a different SSID for 2.5 and 5. In the Smart Connect mode the recommendation is for the same SSID on both. Now that things are connecting I didn't challenge the thing.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't see a way to mark a topic as self-solved, so I'll just post this and see if I can mark this as solved.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Upgraded from WNR3500v1 to RAX50 - old Windows 7 work laptop will not connect SOLVED
Hi redgatorva,
Thanks for sharing your experience as it may help others who may experience the same issue.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
