fortner28
Jul 28, 2021Follower
WIFI mesh system AX3600 loses internet connection
I purchased this system to enable whole home high speed access. When everything works it is really great. Really fast. It seems like I lose internet on the router or its satellites once a week and I need to reset the system. Does this seem to be normal? It's not the end of the world but it seems that it drops internet at the most inconvenient times.
1 Reply
what actual system do you have? AX3600 is a speed not a model.
Also, you posted in the AX router forum and not the AX mesh system forum (if thats the one you have)
what firmware is on it?
what modem/gateway is it connected to?
when it goes down, what actually happens? does wifi disconnect, does it connect but say "connected, no internet", what actual results do you get?
