- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wake on Lan with RAX80
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wake on Lan with RAX80
Hello EphraimB,
The RAX80 currently does not support this feature.
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been able to use Wireless Wake-on-LAN in Windows 10 with my RAX80. Here are the steps I took.
1. Enable WOL and/or wake on USB in the bios;
2. I have my router issue a static IP to my computer;
3. Set up the Dynamic DNS Netgear service on the router;
4. Forward port 7 to the computer;
5. Finally, I wake it up "RemoteBoot" (iphone app). I enter in my router's IP address, Mac address, port 7, and DNS address.
Hope that helps someone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used port 7. I do not recall if I tried 9 and it did not work. I did not need to forward both ports. However, you may need to try one then the other or both.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> 5. Finally, I wake it up "RemoteBoot" (iphone app). [...]
If you're using a program which runs on some other system, then the
router itself is not really doing anything with WoL.
> So I need port 7 and not port 9?
You'd need to use whatever the WoL program needs you to use. But,
again, it'd be the WoL program which would be doing the WoL work, not
the router.
> Which routers do?
I know nothing, but I've never see WoL mentioned in the documentation
for any consumer-grade Netgear router. I seem to recall seeing reports
here of people using a Raspberry Pi with a WoL program. In that case,
too, the router would not be doing the actual WoL work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I forgot to mention, I believe windows 10 requires you to turn off fast boot for WOL to work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Go into the device manager, select your network adapter, and make sure you have enabled both "Allow this device to wake the computer" and "only allow a magic packet to wake the computer."
