Reply
Wifi Disconnection-restarting computer to connect
flamesafe
Follower
After installing my Nighthawk 6-Stream Wireless Router I have experience a problem I did not experience with my former wireless router.  At least once a day I have to restart my computer to recover a connection.  This is the only way to recover my connection.  If I try to reconnect in my network settings it will not connect.  I believe this is a possible driver issue.  I did not have this problem until I installed this router so I know that my computer is not the problem.  Anybody experience this?
Message 1 of 2
Christian_R
NETGEAR Moderator
Re: Wifi Disconnection-restarting computer to connect
Hello flamesafe,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 224 views
  • 0 kudos
  • 2 in conversation
Announcements
