Reply
Windows XP and Wifi 6?
danj77z
Follower
Hello I have a RAX75 Wifi 6 router.
I'd like to get an old Windows XP computer connected to the internet. The computer sees the 2.4 ghz band fine and tries to connect, but never does. The 5 ghz band is nowhere to be seen.
Is this even possible? To connect an old, clunky computer to my new wifi 6 router?
Thanks
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: Windows XP and Wifi 6?
Hello danj77z,
Does your old computer support WiFi 6? If not, you may need to disable WiFi 6 (aka AX WiFi) in the router's settings.
https://kb.netgear.com/000060387/How-do-I-disable-the-AX-WiFi-feature-on-my-NETGEAR-AX-router
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 556 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
