Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
bought netgear c7000v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-12-08
04:05 PM
2022-12-08
04:05 PM
I would like to use my older c6250 as a wifi extender access point from my cable modem connected 7000 can this be done how?
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2022-12-09
06:51 AM
2022-12-09
06:51 AM
Re: bought netgear c7000v2
If you set the C6250 for a IP address string as what's on the C7000, then disable the DHCP server on the C6250, then connect the C6250 to the C7000 using any LAN port in back with a ethernet cable, it should work as a wifi AP. You should be able to access the C6250 by using it IP address you set up on it. I would set the IP address to 192.168.1.62. I recommend setting the wifi settings to use a different SSID name and WiFi channels need to be far apart as well.
Message 2 of 2
Announcements
