Reply
cannot see one of the two external usb drive
sgau
Tutor
I got 2 usb drives connected...
one is usb 2.0 and other one is 3.0
both can be seen as available drives in "Advanced Setup->USB Settings->Available USB Devices"
However, in windows I can only see usb 2.0 drive in \\rax120
Can anyone tell me why I cannot see the other drive?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 5
Accepted Solutions
Guru
Re: cannot see one of the two external usb drive
Not formatted for your laptop. It has to be in a proper format for the router.
What are the USB drive requirements for my Nighthawk router? | Answer | NETGEAR Support
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 4 of 5
All Replies
Guru
Is it formatted properly?
Message 2 of 5
sgau
Tutor
yes, works fine when the drive is connected to laptop directly.
Message 3 of 5
Guru
Message 4 of 5
sgau
Tutor
got it, thanks!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 137 views
  • 3 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
