iamharry
Dec 02, 2020Aspirant
devices keep getting disconnected from RAX75 router
I had this router for few month and it used to work fine. But from couple of months all the devices keep getting disconnected all at once from the router and it's driving me crazy as all the things I did haven't helped. It's on latest firmware 1.0.3.102. Would appreciate any help/suggestions
have you factory reset it and did a clean install on it lately?
The rax devices have been getting frequent firmware updates and respond favorably to factory reset and clean installs (not from backup)
- iamharryAspirant
I tried reboot which hasn't helped. By clean install do you mean something like this https://kb.netgear.com/19841/Reinstall-the-firmware-on-a-router-without-the-setup-CD-recovery-tool
- iamharryAspirant
That process is so outdated. My mac doesn't have a LAN port to support it as per the instructions :( I wish costco can take it back. I bought it in March and paid just short of 300 bucks for this half baked product
