× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
forgot my admin password
ulengdad
Follower
I have an RAX50 and forgot my admin password, actually fat fingered it 4 months ago when I set it up.
I can't get to the recommended login web page and changed phones in the meantime, yuup the app did not transfer either. That's what I get for going from Android to Apple.
Can anyone help me out here?
Message 1 of 2
res1983
Guide
Re: forgot my admin password
Hello. If you forgot your password, you can run thru the security questions you created during the first setup. However, if you are unable to remember the answers, you can always do a pin hole reset on the back of the device. Then you can use the IOS or Android app and do another install. The only down side to that is if you labeled devices and didn't back them up, you would need to relabel them.
If you decide on the pin hole reset, let the unit be powered on and press and hold the reset button for 30-45 seconds. Once that is done, I find it best to do a power cycle on the unit and once fully powered on, start the onabord process again.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 712 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
