- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear genie
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,netgear genie won't accept my username
which it says is my e-mail address,My e-mail address has not changed since I bought the router.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sure---As somrone in the community suggested I did a factory
reset and then followed the instructions in the router manual.
It worked out fine.
Thank you.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear genie
Hello paperquill,
May you try the default credentials below.
Username: admin
Password: password
Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear genie
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
What are you doing and what happens?
Unfortunately, "won't accept" doesn't tell us what error messages and prompts you see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear genie
hankkkk
thank you.i did find a fix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear genie
That's good news.
Care to share it with as? You could save someone else from going through the same problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It worked out fine.
Thank you.
