Reply
outside extender AC3000 connect with ax11000 (rax200)
Rac200
Tutor
I have the router rax200. I want to have better internet outdoors, so I am thinking of buying the outdoor extender AC3000. Can these two work together or is there a better solution? Like to hear. Thank you.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 6
Re: outside extender AC3000 connect with ax11000 (rax200)
AC3000 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
If you mean the RBS50Y. check the manual for the various modes.
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 6
Rac200
Tutor
OK thanks. I found these for outdoors https://www.netgear.com/home/wifi/mesh/rbs50y/. do you think this can be used with the rax200?
Message 3 of 6
Should work.
Try this:
Can I use an Orbi satellite with my existing router? | Answer | NETGEAR Support
Orbi RBS50Y - Mesh WiFi Range Extender | NETGEAR
Just another user.
Message 4 of 6
Guru
If you have an option of hardwiring it in, there's also things like the WAX610Y (outdoor AP) that you could utilize outdoors.
https://www.netgear.com/business/wifi/access-points/wax610y/
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 5 of 6
Rac200
Tutor
Thanks
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 272 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
