Discussion stats
  • 3 replies
  • 161 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
"No cases found" in my support portal
I've submitted 2 cases now but when I go to my.netgear.com it does not show any open cases.
How do I check for my open cases?
Thanks!
Frank Cano
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 4
Highlighted
NETGEAR Moderator
Re: "No cases found" in my support portal
Hi fcano42,
You should have received an email confirmation with the case number(s)/details. If you did not, please provide me with your email address in a private message.
Christian
Message 2 of 4
Highlighted
Hi Christian,
Thanks for your reply. I did receive and email when I opened the case and again when there was a response.
But there was no link in the email to view the response and when I go to check my support it says “no cases”
Message 3 of 4
Highlighted
NETGEAR Moderator
Hi Frank - May you send me a private message with the email address you used to open a support case.
Christian
Message 4 of 4
