Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rax35v2 : lost cable connection when LED showed super busy
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-18
10:25 PM
2020-12-18
10:25 PM
I have the updated version of firmware. After I replaced with this AX WiFi6 router I kept loosing cable connections. When it happened, the LED showed busy signals. WiFi worked fine. I did not have this problems when I used my previous router. After I restarted router, it worked fine again. Any suggestions?
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-12-19
02:11 PM
2020-12-19
02:11 PM
Re: rax35v2 : lost cable connection when LED showed super busy
What actual version number are you on?
What modem/gateway is it connected to?
have you tried a simple factory reset and reinstall? The RAX devices have responded favorably after firmware changes to factory reset and manual reinstall (not from backup)
Message 2 of 2
Announcements
