× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Netgear Switch
Rambo126
Follower
Netgear Switch
Hello,
Should i get a netgear nighawk switch for only one device or for a lot devices i want to couple with the ps4 and the netduma.
Message 1 of 2
JohnC_V
NETGEAR Moderator
Re: Netgear Switch
Hi Rambo126,
Welcome to our community!
If you wanted to add more ports on your network then you may purchase a switch but if it seems that you do still have available ports on the router, I suggest you to just use those ports.
Message 2 of 2
Discussion stats
  • 1 reply
  • 3723 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
