× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Nighthawk S 8000 switch
q8ducati
Follower
 Nighthawk  S 8000 switch | GS808E
by connecting OS windows 10 pc to port 1 and access point to port 2 in Nighthawk S8000 switch, can use Link aggregation in this case
for port 1 and port 2 to get maximum speed?
and what is the best connection for these cases?
case 1: connect main router >> switch >> AP
case 2: connect main router >> AP >> switch
Model: Nighthawk S8000| GS808E Gaming & Streaming Switch
Message 1 of 2
TheEther
Guru
Re: Nighthawk S 8000 switch
Link aggregation is used to connect multiple links between two devices. For example, between a switch and a PC with multiple Ethernet ports.
You can't enable link aggregation on two switch ports that go to different devices.
Message 2 of 2
Discussion stats
  • 1 reply
  • 1900 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
