- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
S8000 Nighthawk Gaming & Streaming Switch firmware update waiting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi
30 minutes ago I updated the firmware for my Nighthawk Switch S8000 to 1.0.2.3 and I am still seeing the notice that reads:
"Firmware Update
Do not interrupt the network connection or power the switch during this process.
Do not disconnect or power down the switch until the process is complete."
For past experience with routers, this process takes no longer than 5 minutes and I have been waiting for 30 minutes, I am thinking something is wrong.
Since the notice in front of me states not to disconnect or power down, what are my choices? and how do I proceed in order not to brick the switch?
Thank you
Mario
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
I would like to have a follow up on this thread. Please let us know if everything works ok now or you still need further assistance. Just in case that the reply was the solution to your problem, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: S8000 Nighthawk Gaming & Streaming Switch firmware update waiting
Hi usamartinez,
Welcome to our community!
A part of workaround is that you can try to ping the S8000 to test if it still connected to the network and if it is still responding then you can try to re-open the browser and access the GUI again. Please keep us posted.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, Yes, it worked, I used Firefox and it worked as it should.
I was worried that if I closed the window, I would brick the switch.
Thank you
