- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
2.4 Ghz Digital Frame doesn't work with RBR850 and 2 satellites...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I purchased 2 identical digital frames which only work at 2.4 Ghz. I'm using the RBR850 router with 2 satelites. I couldn't send any pictures to the frames no matter what I tried. My brother took one of the frames to his place and everything worked great.
The difference between his router setup and mine is that the RBR850 does not separate 2.4 and 5 Ghz. My brother has the option to choose 2.4 Ghz over 5 which is why he was able to make things work on his end.
How do I separate 2.4 and 5 Ghz on the RBR850 so that I can choose 2.4 Ghz on the digital frame?
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 2.4 Ghz Digital Frame doesn't work with RBR850 and 2 satellites...
are they connected to wifi?
Are you able to see them on your network?
What modem/gateway is the orbi connected to?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Yes, they are connected to wifi.
I can see them in the network.
The router is connected to a Arris Surfboard S33.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
@Orbidude wrote:
Hi,
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the link, FURRYe38. I didn't know about the dedicated forum specifically for the Orbi AX (WiFi 6) products..
- Mark as New
- Bookmark
- Subscribe
- Permalink
No Worries, we'll get this moved for ya.
