Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
5GHZ channels not available anymore
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-28
09:25 PM
2021-09-28
09:25 PM
Hello,
Since the last firmware update V1.0.4.76 I can't connect anymore to none of the 5GHZ channels anymore. I can see them with the Netgear genie app on my PC but I'm not able anymore to change the settings. I also notice that all channels have not the same SSID name, bot none I'm anle to change.
Can anyone help me to solve this issue?
Regards DWAL
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2021-09-29
06:43 AM
2021-09-29
06:43 AM
Re: 5GHZ channels not available anymore
Whenever I run into an issue after a firmware update, I recommend a factory reset and reinstall. (don't use a backup configuration).
If that doesn't help, then I'd recommend downgrading the firmware a version.
Message 2 of 2
Announcements
