- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
6700v2 WiFi-Wi-Fi Router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m currently using a Xfinity hotspot on a long term basis. I am concerned being exposed to being hacked.
1. Would Xfinity have a problem with me implementing a router with multiple devices behind the router?
2. Is it possible to configure two separate WiFi networks on a single 6700v2 with routing between them?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
You're going to want something that supports wisp mode. The R6700 doesn't.
You'll want to look at a travel router. GL-iNet makes pretty solid routers that some have support for wisp mode.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: 6700v2 WiFi-Wi-Fi Router
Xfinity hotspot?
What exactly (model) are you referring to?
Tough to give advice with general statements.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi. Xfinity has a feature which creates hotspots on their subscribers’ modems. I can have access to such a hotspot by utilizing my son’s Xfinity credentials elsewhere, which works.
Since I’m on a hotspot, I’m exposed to anyone who also has access to that hotspot. I want to limit my exposure and figured if I can use a Netgear 6700v2 (of which, I own,) to log into the Xfinity hotspot and have my devices obtain WiFi from the Netgear. I assume if it can be done, then I would have some amount of protection. Can it be done? I’m not sure of the mode.
Hope that’s clear.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
