Orbi WiFi 7 RBE973
Reply
8TB Hard Drive on Nighthawk X8 R8500
Swerve83
Apprentice
Does the Nighthawk X8 (R8500) support 8TB Hard Drives???????  My 5TB WD My Book is no longer supported it seems on the USB 3.0, but it works on the USB 2.0 port. I am upgrading to a large storage anyway and want to see about making a 8TB work before I get my NAS up and running through my server/switch.
Thanks for any help/advice.
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 1 of 4
Accepted Solutions
Re: 8TB Hard Drive on Nighthawk X8 R8500
You can get an idea of what you can use from this page:
Will my USB drive work with ReadySHARE | Answer | NETGEAR Support
You may be pushing it with 8TB drives.
For serious networking use Ethernet.
Message 2 of 4
All Replies
Message 2 of 4
Swerve83
Apprentice
Yah I ran across this link earlier. Figured 8TB would be pushing it. Eventually I will be using a swich with rack holding 5-10 drives, totaling around 36TB.
Thanks for your reply!
Message 3 of 4
antinode
Guru
   As opposed to what, exactly?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2549 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
