Orbi WiFi 7 RBE973
Reply
AC 1200 Smart Wifi Router, Images not loading
Adryan475
Okay so as I said I have that router and I updated to the new firmware (V1.1.0.106_1.0.1) and now images are not loading on Instagram, Facebook etc...
ive check on both my iPad, iPhone and computer and it's the same problem for all, not just those two apps as well, even sites online are not loading images.
it's definitely the Router because the modemn loads them fine...I factor reset the router twice and still no help, so it's definitely the new firmware, is what I think. Is there a way to restore the previous firmware or a way to just fix this problem
Message 1 of 8
Guru
Re: AC 1200 Smart Wifi Router, Images not loading
What modem do you have?
What router do you have? AC1200 is a speed, not a model.
did you every try downgrading the firmware? maybe the firmware introduced a bug in your setup
Message 2 of 8
Adryan475
@plemans The model is r6230 and i didnt downgrade the firmware, not sure how im even supposed to do that
Message 3 of 8
Guru
to downgrade you simply download the older firmware, unzip it, and then follow the manual firmware update process from the manual. you just use the firmware you downloaded
Message 4 of 8
Adryan475
ok well i did it just now and im still having the same problem unfortunately...I still have interent access and can load websites fine, but again Instagram i can message people but no pictures are loading and Youtube is loading as well but videos are not playing.
Message 5 of 8
Guru
what modem do you have?
Message 6 of 8
Adryan475
@plemans
Umm...it's a Huawei EchoLife Hg8245H
sorry for taking so long to reply, I contacted Digicel (my isp) as well and after a long conversation and troubleshooting it seems nothing is wrong on their side. I believe this as well because if I connect directly to my modem everything is fine, it's only when I connect to the netgear router
Message 7 of 8
Guru
the EchoLife Hg8245H has its own integrated router. It causes a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the echolife in passthrough/modem only mode. this disables its own routing functions
2. put the netgears IP address in the echolife's dmz
3. put the netgear in ap mode. it disables its own routing functions and lets the echolife manage them. wifi/ethernet works as normal.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1220 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
