Orbi WiFi 7 RBE973
Reply
AC1900 connection in Korea
Bardzo
Follower
I’m in South Korea on a rotation for the next 9 months, brought my router with me to use wifi. Unfortunately, a South Korean wifi service technician told me my net gear router will need some adjustments to its settings to work in South Korea. How can I make my router work?
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Guru
Re: AC1900 connection in Korea
You have the C7000? I'm not even sure if its compatible with their ISP's? (you'd have to check with the isp)
If it does work, then you'd need to change the region code to the korean region. It should be part of the firmware/provisioning from the isp.
Or what router do you have?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 595 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
