Orbi WiFi 7 RBE973
Reply
AC1900 router Model R7000
foxyrph
Follower
Just purchased this router.  Everything seems to be working okay, but I have a Belkin Router that's part of my security alarm system.  It is plugged into Ethernet port #1.  The LED on that port is no longer white.  It is now orange/amber.  Received a brief message saying the unit (Belkin router) was under investigation.  As I said, the Netgear Nighthawk router and the Belkin router seem to be working okay.  Is there anything I should do about this?  Thank you for the courtesy of a reply.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 1 of 2
antinode
Guru
Re: AC1900 router Model R7000
> [...] Ethernet port #1. The LED on that port is no longer white. It
> is now orange/amber. [...]
      https://community.netgear.com/t5/x/x/m-p/2080468
> [...] Is there anything I should do about this? [...]
   Bask in the warm amber glow?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 339 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
