- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC2100 firmware failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
My AC2100 firmware update failed. Now the power light is solid orange. When I depress and hold the reset button, the power light blinks white. Tried to obtain guidance thru netgear manual and live chat but netgear wants me to buy a service contract. Does anyone know the procedure to download the latest firmware and install it in the router? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC2100 firmware failure
The blinking LED tells us that you have corrupt firmware on your R7200.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If that fails, you are into TFTP country.
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
