Orbi WiFi 7 RBE973
Reply
AC2200 Tri-Band WiFi Range Extender(EX7700) configuration as access point
filida
Follower
Hi all, I've an AC2200 Tri-Band WiFi Range Extender(EX7700) and I want to configure it as an access point. I tried two times but after a while the configuration process end asking me to retry. Is there any thing to consider in order to successfully confgure the EX7700 as Access Point?
Thanks
Message 1 of 2
Guru
Re: AC2200 Tri-Band WiFi Range Extender(EX7700) configuration as access point
Do you have it connected to the router over a hardwired connection when attempting to set it up in access point mode?
Message 2 of 2
Discussion stats
  • 1 reply
  • 260 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
