Reply
AC2200 nighthawk
Sburns
Tutor
AC2200 nighthawk
Bonjour
J’ai acheté ce produit neuf et le Réseau Netgear_ext n’apparaît pas dans la liste.
J’ai essayé plusieurs manipulations mais rien n’y fait.
Que dois je faire? Merci pour votre aide
Message 1 of 6
Accepted Solutions
Guru
Re: AC2200 nighthawk
glad its working well for you!
If you markt the solution as solved, it might help someone else as well as it can save time for others that might be working on these 🙂
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 6 of 6
All Replies
Guru
did you try setting it up using the wps install option?
What extender is it? AC2200 is a speed not a a model.
I'd imagine its one of the mesh extenders sinces its an AC2200 and the higher performing extenders are mesh.
If that's the case and you set it up using wps, it uses the same ssid as your router. You can disable the "onewifi" function if you'd like.
https://kb.netgear.com/000044732/How-do-I-enable-or-disable-One-WiFi-Name-on-my-Nighthawk-Mesh-WiFi-...
Also, you posted in the router section and not the extenders forum.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Message 2 of 6
Sburns
Tutor
Hi
Thanks a lot for your reply. Sorry I could not find the way to answer back to you 😞
I got a new mesh extender : nighthawk X6
And I will try to set it up today 🤞
Should I disable the one wifi first?
Should I use WPS preferably?
Thanks a lot for your help
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 3 of 6
Guru
@Sburns wrote:
Hi
I got a new mesh extender : nighthawk X6----Not a model number. Look at the label and it'll have the model number.
Should I disable the one wifi first?----do you want it to function as a mesh extender? If so, then use the onewifi. If you prefer it have a seperate ssid, then disable it.
Should I use WPS preferably?----You can try WPS and see if it works. Some ISP supplied routers are poorly coded and it has issues. So if it doesn't work, use the installation assistant and not wps.
Message 4 of 6
Sburns
Tutor
Thank you so much
Everything is fine
It worked perfectly! I think the first one was damaged .
We have a perfect wifi connexion in the whole house now.
Thanks again for your help
Have a great day
Message 5 of 6
Guru
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 435 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 6E
