- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC750 Internet Port DNS stuck on static numbers
- Mark as New
- Bookmark
- Subscribe
- Permalink
To troubleshoot a connection issue, one internet suggestion was to change DNS to static numbers (8.8.8.8, 8.8.4.4) and try. Didn't work and I switched back to DHCP. Now I have lots of connection issues and when I check on routerlogin.net-Advanced Home page, the Internet Port page shows DNS still at 8.8.8.8, 8.8.4.4. I immediately did a factory reset. In Internet Setup DNS shows DHCP checked but also pri/sec settings of 8.8.8.8, 8.8.4.4 which I can manually reset to blanks but they stubbornly keep reappearing. Router's DHCP server is "ON". I wish I knew if any of this matters. I wish I knew what I'm doing wrong.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC750 Internet Port DNS stuck on static numbers
dhcp server and getting the dns automatically from the ISP are different things.
DNS should just be a back to switch to.
A factory reset should clear it out though.
Are you sure you pushed and held reset for 7-15 seconds while the device was powered on?
You'd have to fully reinstall the device if you factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I appreciate you replying! Yes, I held the reset button until all green LEDs were blinking and I did have to reinstall using routerlogin. Your comment leads me to believe that this might be unusual, but may not be the cause of any issues I may be having with connectivity - specifically a solar inverter monitoring app and TV streaming accounts - all of which claim no internet when directed to connect to my router's 2.4 service.
- Mark as New
- Bookmark
- Subscribe
- Permalink
what modem/gateway are you connected to?
