- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Acceso Remoto a router R7000
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tengo un Router R7000 Que enlaza dos redes diferentes.
En la punta WAN tengo La direccion 10.193.48.53
En las puntas LAN tengo direcciones del orden de 192.168.1.0
El router tiene la direccion LAN 192.168.1.1
Desde la red LAN puedo accesar el Internet que esta en la red 10.193.48.0
Desde la red LAN puedo accesar el enrudaor por el puerto 192.168.1.1
Desde la Red 10.193.48.0 puedo hacer un ping al puerto WAN del enrutador y me contesta.
No puedo accesar el portal de administracion del router desde la red 10.193.48.0
Alguien Sabe como hacerlo??
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Acceso Remoto a router R7000
In inglese per favore
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode | Wifi Router XR500 and RBK863 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've a R700 router that links two different networks
In the WAN side The IP address port is 10.193.48.53
In the LAN side the address are in the order of 192.168.1.0
The router LAN address is 192.168.1.1
From the LAN side I can access the internet hosted in the 10.193.48.0 network
From de LAN side I can access the router by the port 192.168.1.1
From the 10.93.48.0 network I can make ping to the router's WAN port (10.193.48.53) and answer is ok.
I Can't access the router's GUI page via web browser from the 10.193.48.0 network.
Does somebody knows how to do these???
- Mark as New
- Bookmark
- Subscribe
- Permalink
Usually can't ping the routers web page at 192.168.1.1 from the WAN side.
Do you have Remote Management enabled? This allows access to the routers web page from the WAN side. Otherwise only from the LAN side can you access the routers web page.
