Orbi WiFi 7 RBE973
Reply
Adding satellite
Mrlock1
Follower
Adding satellite
Nighthawk mesh ax1800 mk63 can you add more than 3 satellites
Message 1 of 2
Guru
Re: Adding satellite
I've read you can add more but the performance drops after the 2-3 satellites because its only a dual band system.
If you're using a wired backhaul, I'd imagine you can use significantly more  like the orbi system
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 450 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
