Orbi WiFi 7 RBE973
Reply
Admin password
Brian55
Follower
Admin password
How do I get support in resetting my admin password as nothing I think of works.
cheers
Message 1 of 2
Guru
Re: Admin password
If password recover doesn't work,
https://kb.netgear.com/24220/How-do-I-recover-my-NETGEAR-admin-password-using-the-password-recovery-...
Then you'd need to factory reset to get back in. Push and hold reset for 7-15 seconds while its powered on.
Then follow the install guide for your device.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 801 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
