Orbi WiFi 7 RBE973
Reply
All wireless suddenly lose connectivity until the router is restarted
WiFizzle
Follower
Firmware Version
V1.3.2.134_10.1.66
Look at this photo, here my laptop is touching the wireless router, the routers internet and 5g lights are lit, Windows says it connected, but the routers address of 192.168.1.1 cannot even be reached. Wired is fine and a few moments ago all wireless devices as well, then all wireless device are put in this state. Restarting the R7000P is the only way to resolve this issue and its nearly a daily thing.
Its not an issue with other devices, its an issue with this router.
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 2
Guru
Re: All wireless suddenly lose connectivity until the router is restarted
When did it start having issues?
Did you try a factory reset and reinstall?
I'd also recommend trying a downgrade on it. Not all R7000P's played nicely with netgear armor. The version of firmware prior to armor is 1.3.0.20
you could try installing that version, then do a factory reset and clean install (not from backup).
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 226 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
