Orbi WiFi 7 RBE973
Reply
Any way to get Facebook wifi to work with Nighthawk RAX200?
51synister
Follower
I'm using a Nighthawk RAX200 in a commercial building, and I'd love to be able to enable Facebook Wifi for it. The option does not show up in the UI. Is there a way to use Facebook wifi with a Nighthawk router?
If I can't get this to work with the Nighthawk, I'm going to have to replace it and I'd like to avoid that if possible.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Guru
Re: Any way to get Facebook wifi to work with Nighthawk RAX200?
the only consumer netgear router I show that supports it is the R6300v2 (older router).
https://kb.netgear.com/24279/How-To-Configure-Facebook-Wi-Fi-On-Your-NETGEAR-Router
Everything else has been business grade equipment/access points.
https://kb.netgear.com/000055556/How-do-I-set-up-and-enable-Facebook-Wi-Fi-on-my-wireless-access-poi...
If you're using it for a business, the business grade would probably be the router to go so you can seperate customers data from yours
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 290 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
