Orbi WiFi 7 RBE973
Reply
Attaching Router to Gateway
IVDan
I have been using a 5G Mobile Broadband gateway (modem + wifi router) for the past several months but was having some issues with the gateway allowing some devices to connect.
So just today I turned off the wifi on the gateway and attached my Nighthawk wifi router instead.  So far everything is working great - all devices are connecting.
My questions is --- should I activate the IP PASSTHROUGH mode available on the gateway?  I am seeing in the Nighthawk Logs repeated DOS attacks being recorded with the IP address of the gateway - I am presuming these are not really attacks.
Anyway just looking for advice on how to optimize my set up.
Thank you!
Message 1 of 3
Guru
Re: Attaching Router to Gateway
that'll fix the double nat.
But if its working as it should and giving good speeds, why fix what isn't broken.
Message 2 of 3
IVDan
Good point about don't fix what isn't broken! Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 489 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
