lashcraft302
Nov 13, 2020Follower
Blocking Roblox
What is the best way to block the entire Roblox site begining from my router? I know this was asked before, but even though I have put EVERY form of Roblox and the site into the "Block Site" feature, it still allows access to the site. Is there even a way to block the entire site and it contents from the router? Thanks for the help.
Problem is that googles mesh system doesn't have an access point mode/bridge mode when using more than 1 mesh device.
https://support.google.com/wifi/answer/6240987?hl=en
you could go:
modem------google mesh ------mesh satellites
RAX120 (access point mode)
That'd let the google run as primary router and still give you the option of the RAX120's wireless
1 Reply
- DarrenMSr. NETGEAR Moderator
You may want to look are circle parental controls to block something like this.
https://www.netgear.com/landings/circle/
DarrenM
