Orbi WiFi 7 RBE973
Reply
Bonded MoCA 2.0
Activity61
Follower
Bonded MoCA 2.0
Hi @All
Is the standard "bonded MoCA 2.0" supported by the Netgear nighthawk ac 1900 dual band wifi router?
Thanks for the answer.
Regards
HJ
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 4
Accepted Solutions
JamesGL
Master
Re: Bonded MoCA 2.0
Hi Activity61,
If there is no other configuration that needs to be done on the MoCA 2.0 device then it should be able to work with the R7000. As long as is provides internet connection then the router should be able to work.
JamesGL
Community Team
Message 2 of 4
All Replies
JamesGL
Master
Re: Bonded MoCA 2.0
Hi Activity61,
JamesGL
Community Team
Message 2 of 4
PJS-Tex
Re: Bonded MoCA 2.0
I am looking to purchase a MoCA adapter. On the listing for the adapter, it states in the desription that:
"Requires that your router support bonded MoCA 2.0"
Does the router support it?
Th listing is below for the Moca adapter
https://www.amazon.com/Actiontec-Bonded-Ethernet-Adapter-ECB6200K02/dp/B013J7O3X0/ref=sr_1_1?ie=UTF8...
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 3 of 4
TheEther
Guru
Re: Bonded MoCA 2.0
I believe you can ignore that requirement.  As far as the router is concerned, the MoCA adapter will look like an Ethernet cable.
Message 4 of 4
Discussion stats
  • 3 replies
  • 10471 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
