Orbi WiFi 7 RBE973
Reply
Burned out Ethernet Port
hydrasport
My modem/router has 4 ports on the back. One port is dead. I need to plug 4 devices into the router. Two of the devices are security cameras that will not be used online very often and not at the same time. Can I install an 2 -1 adapter that will allow two devices to be connected into one port? How bad will this hurt the performance of the cameras if not used at the same time?
Message 1 of 3
Accepted Solutions
Guru
Re: Burned out Ethernet Port
I wouldn't use an "adapter".
I'd buy a simple gigabit switch.
A 5-8 port one is usually around $20-30
Message 2 of 3
All Replies
Guru
Message 2 of 3
hydrasport
I found this splitter but I think you are correct about needing a switch. This only allows one input at a time. The cameras would both be trying to "input" at the same time.   RJ45 Ethernet Splitter Cable, Rellyuar RJ45 1 Male to 3 X Female Port LAN Ethernet Network Splitter Adapter Cable Suitable Super Cat5, Cat5e, Cat6, Cat7 LAN Ethernet Socket Connector Adapter
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1445 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
