- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CAX 80 password reset loop
- Mark as New
- Bookmark
- Subscribe
- Permalink
Somebody please help getting out of this before I'll trash this (censored)
Router is stuck in a pwd reset loop at address https://EXTERNAL_IP:PORT/PwdRec_index.htm
I did try to reset it although there was NO need whatsoever, and nothing, still getting bounced to that page.
I think I did have this issue before but don't remember how I fixed it.
I'm out of the country so please avoid saying "you could try to reset to default" since I have no direct access to it, and I'm sure that's not what I did before.
This is happening on both Chrome and (yuck) Edge.
Firmware of the CA X 80 is the latest 2.1.5.2
Any idea?
Thank you!!
Chrome Version 114.0.5735.90 (Official Build) (64-bit)
Edge Version 113.0.1774.57 (Official build) (64-bit)
Win 11 home version 22H2 build 22621.1702
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CAX 80 password reset loop
do you have the serial (don't post it here, just asking)?
If so, use that and make sure to meet the minimum password requirements.
If you don't, it'll loop.
I suggest
10 characters
1 special
1 upper case
1 lower case
1 number
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi plemans
as I said I did try to reset the password and it does meet the requirements, to the point it actually confirm the pwd was changed.
The SN is cached as you can see (deleted part of it, obviously) so it's correct.
But once done, I'm back to the pwd reset page
- Mark as New
- Bookmark
- Subscribe
- Permalink
Id power off the modem for 30 seconds then back ON.
Using a different browser, MS Edge or FireFox or Opera, try logging in to the modems web page. Be sure your interring in the correct PW values.
Be sure to clear out all browser caches before entering the modems web page.
If this fails, try a full on factory reset and setup from scratch. Walk thru the setup wizard and this time re-enter in a new PW. I would avoid using spcial characters. I use Two Upper case characters, 3 lower case characters, then numbers afterwards and it works for my CAX80. UUabcde123 for example.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would love to reset it and power it off.
If only i could login LOL
- Mark as New
- Bookmark
- Subscribe
- Permalink
Something to try when you get back.
Or have someone help you with.
Good Luck. Safe travels.
