Orbi WiFi 7 RBE973
Reply
CAX30 is blocking my Oculus from connecting
Brettmcm
Apprentice
My CAX30 is blocking my Oculus from connecting to the internet, yet I go to the router, it doesn't show it as blocked. I go to Armor it tells you less than nothing, what a waste of money that was, total garbage. Have you ever seen a security device just say "URL blocked" but NOT TELL YOU WHAT IT BLOCKED??!? Whats the point? It's literally good for nothing.
So now what do I do? Nothing says it's blocked but no matter what I do, it continues to block it without giving me any options to unblock it. The Nighthawk App...also does nothing totally useless. What is even the point of it? It's of no help whatsoever.
Any help anyone can offer would be greatly appreciated
PS I DO NOT HAVE THE AX8 I HAVE THE AX6 Which isn't an option, because .... of course
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 5
Guru
Re: CAX30 is blocking my Oculus from connecting
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Disable Armor.
Thank you.
Message 2 of 5
Brettmcm
Apprentice
diabling armor didnt help but thank you
Message 3 of 5
Guru
Does putting the device in to the modems DMZ help?
Message 4 of 5
Guru
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1371 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
