Orbi WiFi 7 RBE973
Reply
CAX80 blocking Samsung TV Plus
hxquero
And the second I connect the TV to my T-Mobile hotspot - Samsung TV Plus works as it should!! NETGEAR needs to correct this issue ASAP.
Message 1 of 7
Re: CAX80 blocking Samsung TV Plus
Message 2 of 7
hxquero
I hope not...NETGEAR really needs to standby their products and give consumers what they think they're paying for.  It can't be that complicated - Samsung TV Plus works great on my corny T-Mobile Hotspot LOL!
Message 3 of 7
hxquero
Well, it's been a whole month and no solution.  I'm at my wits end...I will NEVER purchase another NETGEAR product and I'm headed to Best Buy to purchase a Motorola!
Message 4 of 7
Guru
Please post about this over in the cable modem forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
I believe NG put forth a new FW update a bit ago regarding this. Something to try if you haven't already.
"@tamanaco wrote:
The issue with Samsung TV Plus was solved after I updated my CAX80 router firmware to version 2.1.2.6 today. WiFi calling appears to be working after this update as well" <Seems to be working for this user.
Helps to post in the right forum though.
Thank you.
Message 5 of 7
hxquero
I did update the firmware - still didn't work.  Thanks.
Message 6 of 7
Guru
Thank you.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 754 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
