Orbi WiFi 7 RBE973
Reply
CM1000 modem / R8000 router - Smart Connect question
hilton8r
I replaced my Motorola modem/router with CM1000 & R8000 after I started having issues with my iphone & ipad showing connected, even though they weren't. I also had problems with unexplained runaway data usage. Smart connect was set up initially without issue. Over time, I started adding devices, and began having issues with some devices. Two devices were connecting to 2.4G & one device was probably trying to connect to 5G. I split the turned off Smart connect, and was able to resolve all of the issues I was having.
There doesn't seem to be a way for me to use Smart connect to split the 5G and 2.4G bands. I wanted to ask if there is any way to turn Smart connect back on and force those 3 devices to a specific band. I wanted to ask before going through the effort of switching the essid / password for all of my devices. I recall trying to reserve ip addresses for specific macs back when I was researching prior to turning off Smart connect, and wasn't having much luck. If I recall correctly, none of those 3 devices could be set up with a static ip. Thank you in advance for any guidance...
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: CM1000 modem / R8000 router - Smart Connect question
No way to force a device on a band with smart connect enabled it will automatically pick which band which device goes on.
DarrenM
Message 2 of 3
All Replies
DarrenM
DarrenM
Message 2 of 3
hilton8r
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 635 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
