KatLaz's avatar
KatLaz
Follower
Sep 27, 2023
Can’t install my Nighthawk AC1900 as it’s not compatible with the new Nighthawk App
Theses websites no longer work to install my model;
Www.routerlogin.net
Or .com
Can any one help?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Www.routerlogin.net
    Or .com
    Which model is that?
    AC1900 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
    Look at the label on the device for the model number.
    If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that sits between this router and the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
    I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Look for the model number on the label on the device.
    That page will also have any software, firmware and drivers for your device, if they exist.
    Begin with the Quick Start/Installation Guide.
    You could also look at the section tghat tells you how to install the router with the browser graphical user interface (GUI). That can be better than using a wifi app.
