Orbi WiFi 7 RBE973
Reply
Cannot access R8000 controls after firmware upgrade
denhuff
router worked wel and i only let it upgrade the firmware automaticly
ive been looking at this forum and find same problems but none with a answer.
factory reset does not work
power led blinks white
i can ping 192.168.1.1
i cannot reach my router by web page
by  netgear genie   i can not control the router same as      same problem
also tried to upload firmware by  TFTP      like explained here          but no result, the led will not go blinking green   when i push the rest button long time
i wil work like a normal router   (computer with cable and internet) but there is no wifi
please   let me know   how i can   reset my router or flash new firmware
Model: R8000P|Nighthawk X6S—AC4000 Tri-Band WiFi Router
Message 1 of 4
Accepted Solutions
denhuff
Re: Cannot access R8000 controls after firmware upgrade
solved by following post.
i used the build in TFTP from windows instead of program TFTP2
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-bricked-during-firmware-update-to-1-0-...
Message 2 of 4
All Replies
denhuff
Message 2 of 4
Congratulations. TFTP is not for the faint hearted.
You clearly know your way around these things, so next time you see a firmware update you might do better to download the files and apply the update manually rather than automatically. That gives you more control.
Message 3 of 4
denhuff
yes, next time i will
took me about a whole day to find the right way.  search the net on a lot of sites and forums
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2773 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
