Orbi WiFi 7 RBE973
Reply
Compatibility with ExpressVPN
JimAdams
Follower
Is the Nighthawk(R) X4S R7800 compatible with ExpressVPN? The only client that shows in my drop down menu is PureVPN. Can I install sofware/firmware from ExpressVPN?
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 3
antinode
Guru
Re: Compatibility with ExpressVPN
> [...] Can I install sofware/firmware from ExpressVPN?
   Why not ask the people who ought to know if ExpressVPN can be
installed on anything in particular?
      https://www.expressvpn.com/vpn-software/vpn-router
Message 2 of 3
microchip8
Master
The R7800 is not supported by ExpressVPN
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1787 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
