Orbi WiFi 7 RBE973
Reply
Corrupt writes to Readyshare
chuckh1958
Follower
I recently added a 1tb USB flash drive to my Nighthawk router to use it as a DLNA server. At first it wouldnt work at all but after searching this community I discovered the router doesnt support exFAT filesystems so I reformatted it as the only other option offered by WIndows 10 - NTFS. Now it recognizes the drives but many of the files I copy to it are corrupt and need to be re-copied. If I plug the same flash drive directly into my PC the copies work fine. How do I fix this? I dony really want to us FAT32 because of the 4g file size limit. I can see myself putting 4k videos on the drive that exceed that.
I should note that I did a quick format of the drive. I thought with changing filesystems I'd need to do a full format and started that, but after 12 hours it was only 10% complete so I cancelled it and did a quick format. That completed in about 30 seconds.
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 216 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
