Reply
DNS Hijacking R8000P- presenting errors, requires fresh frequently
nnagreg
Apprentice
For the past several months,  I've noticed the when using my router as the DNS server,  it appears to act odd, "Site cannot be reached" ,  "DNS address could not be found. Diagnosing the problem" especially to NEW sites or sites that I infrequently visit.
At first I thought maybe it was my ISP,  thus I changed within the router the DNS to 8.8.8.8 along with a variety of DNS servers, single and multiples.  -The problem still persisted
I've then set my local DNS settings to go directly to the 8.8.8.8 - The problem goes away.
This happens with a variety of devices, OSes, & browsers:     Windows 10/11,  RPI, and Android, Edge, Chrome, Brave ( errors out 1st then usually refreshes automatically in about 10 seconds)
Any Ideas?
Thank you in advance, Greg
Some information about my router:
 R8000p Firmware: V1.4.2.84_1.3.42  GUI:  V1.4.1.70_2.1.46.1  IP6V disabled
Debug information pulled today (3/22/2022)   (All files have old odd dates 9/11/2021 - only places that recent files are in /tmp/d2d)
dhcp_dns=8.8.8.8
wan_dns=0.0.0.0
wan_dns1=8.8.8.8
wan_dns_sel=1
services:
15988 nobody 4140 S dnsRedirectReplyd
16068 nobody 1960 S dnsmasq -h -n -c 0 -N -i br0 -r /tmp/resolv.conf -I
16144 nobody 6244 S ddnsd &
========nslookup www.google.com===========
Server: 8.8.8.8
Address 1: 8.8.8.8 dns.google
Address 1: 142.250.190.68 ord37s34-in-f4.1e100.net
Address 2: 2607:f8b0:4009:804::2004 ord38s18-in-x04.1e100.net
========nslookup www.netgear.com===========
Server: 8.8.8.8
Model: R8000P|Nighthawk X6S AC4000 Tri Band WiFi Router
Message 1 of 12
Accepted Solutions
nnagreg
Apprentice
Re: DNS Hijacking R8000P- presenting errors, requires fresh frequently --- UPDATE -- WORK AROUND
UPDATE 4/18/2022
Work Around  (Solved)
Enabled - IPV6 Auto  (set to 6to4 Tunnel)
Hi All,
By enabling IPv6,  the problem went away.
Hope this helps!!
Greg
Message 9 of 12
All Replies
Guru
There is many other posts about DNS issues seen on recent 8 series router FW.
Some report that enabling IPv6 can help. Others mention reverting back to prior working FW version.
NG is aware of the DNS issues. No idea when a fix will be forth coming.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 12
nnagreg
Apprentice
ISP: Midcontinent Communications
Manufacturer: HITRONModel: CODA-45
Message 3 of 12
Guru
CODA-45?? 82?
There should be 4 numbers to the model of this modem...
Message 4 of 12
nnagreg
Apprentice
I've confirmed the Model is CODA-45  (No other numbers)
https://us.hitrontech.com/products/service-providers/coda-45-cable-modem/
Thank you!
Message 5 of 12
Guru
Ok, just checking to be sure.
I recommend you downgrade FW to v.62 and after that's loaded, factory reset the router and setup from scratch.
Message 6 of 12
nnagreg
Apprentice
******** UPDATE *************
4/18/2022
Any thoughts?  Problem still exists
New Firmware applied:   V1.4.3.88_1.3.50
Did a Factory reset and completely re-built the router configuration using the WEB interface.
Problem still exists using windows 11 device :
Seeing 'DNS_PROBE' errors,
Still requires F5 refresh to continue to website during first request
AND now the router does not supply my manual DNS entries to the clients.
Detail below
Advanced Internet Setup:
Get Dynamically from ISP
Use Static IP Address
IP Address 192.168.88.8
IP Subnet Mask 255.255.255.0
Gateway IP Address 192.168.88.253
IP Address192.168.88.8
Subnet Mask255.255.255.0
Default Gateway192.168.88.253
DNS Server8.8.8.8
Domain Name Server (DNS) Address
X Use These DNS Servers
Primary DNS 8.8.8.8
Secondary DNS  blank
Client DHCP info:
IP =  192.168.99.10  (Client IP)
Netmark 255.255.255.0
Gateway:  192.168.99.3
DNS Server = 192.168.99.3 (Its the internal Router IP)
NSLOOKUP  (new Domain names are returned immediately)
> server
Server: UnKnown
*** UnKnown can't find server: Non-existent domain
Message 7 of 12
Guru
Seems like the router is getting a private IP address (192.168.88.#) instead of a public address, ##.##.###.###.
Looking at the modem seems like it doe not have a built in router however wondering if the ISP has it configured differently.
Can you check with the ISP to see if they have the modem configured differently and see if the modem can pass thru a public IP address?
Message 8 of 12
nnagreg
Apprentice
UPDATE 4/18/2022
Hi All,
Hope this helps!!
Greg
Message 9 of 12
nnagreg
Apprentice
Yes, this DHCP behavior is odd with the current version of the firmware.
With my ISP, I've elected to not accept the DNS entries from the provider (Midco.net)
Good news is that I was able to resolve the problem with DNS multiple requests,  see my posted down below.   However,  my DHCP clients still point to the router as the DNS server,  odd.
Thanks for the help!
Message 10 of 12
Guru
Ok glad that worked.
FYI all NG routers use DNS proxy for connected device. NG may have close what you saw in recent FW version.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 11 of 12
mkrejci
Tutor
Thanks, I just setup my R8000P yesterday and have had constant DNS issues with it. I am trying your suggestion regarding turning on IPV6 and will report later if it worked or not.
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 2727 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
