Orbi WiFi 7 RBE973
Reply
DNS_PROBE_FINISHED_NXDOMAIN
cosmothunder
Guide
Ever since i updated to the new firmware
Firmware Version
V1.4.2.84_1.3.42
I've had nothing but issues. problem connecting to websites, problems connecting to discord and certain games jsut not wanting to work. I've tried something called releasing IP, flushing and renewing ip and it works for a few mins then im stuck again with issues. Its driving me crazy. Please someone help me!
Thanks
Message 1 of 14
Accepted Solutions
Guru
Re: DNS_PROBE_FINISHED_NXDOMAIN
So if this problem started with a recent firmware update, you can downgrade back one version of firmware to see if the problem goes away...
Message 8 of 14
All Replies
Guru
What router model are you referring too?
Message 2 of 14
cosmothunder
Guide
Router is Nighthawk X6S
AC3600 Model# R7960P
Modem is Nighthawk CM1100
When i updated my firmware on the router thats when all these problems started.
Message 3 of 14
Guru
Has a factory reset and setup from scratch been performed since last update?
Power OFF the modem for 1 minute then back ON.
Message 4 of 14
cosmothunder
Guide
I just did that and still the same. The message "DNS_PROBE_FINISHED_NXDOMAIN" will come up when trying to go to webpages. Sometimes it will resolve itself and go, other times i have to click reload a few times and it goes.
Also i cannot connect to voice on discord servers. Certain games will not load in game content skins, server browsing etc etc. I got certain games to work maybe 2 out of 20 times. I jsut dont get it. Do i need to fully wipe my computer and start with a fresh compy of windows??? I dont know what i did Smiley Mad
Message 5 of 14
Guru
I would revert back FW Version and see if the problem continues or not.
Message 6 of 14
cosmothunder
Guide
Slow down there lol tell me in dumdum terms please. Sorry im not that techincal with this stuff
Message 7 of 14
Guru
Message 8 of 14
cosmothunder
Guide
How do I roll back the firmware?
Message 9 of 14
Guru
Download older version of FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
You can find FW files here for yoru model router:
https://www.netgear.com/support/
Message 10 of 14
cosmothunder
Guide
Okay thanks. I will try this tonight. Sorry I'm kindof slow when it comes to this stuff
Message 11 of 14
Guru
Message 12 of 14
cosmothunder
Guide
That worked. Thank you oh wise one!!!
Message 13 of 14
Guru
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 3867 views
  • 4 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
