Orbi WiFi 7 RBE973
Reply
Did R7000 1.0.6.54 get pulled?
sohcrates
Follower
All links to 1.0.6.54 seem to lead nowhere.  "Requested file does not exist"  Another failed beta?  Are we going to just give up on Arlo support for this router?  I think at this point, for our troubles, we all deserve a free Arlo base station.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 26
Accepted Solutions
ElaineM
NETGEAR Employee Retired
Re: Did R7000 1.0.6.54 get pulled?
Hello @sohcrates
Welcome to the community!
The file is now updated and you may download the beta.
It's just that the link got expired.
Message 2 of 26
All Replies
ElaineM
Hello @sohcrates
Message 2 of 26
sktn77a
Virtuoso
"You can now download the beta"? All netgear firmware appears to be "beta" as of late! Sounds like it's well passed time to fire the programming team and hire someone who knows what they are doing!
Message 3 of 26
Henrychung828
Hi Elaine, could you share the download link again for R7000 Firmware 1.0.6.54? I still not able to download by the original link.
Message 4 of 26
Henrychung828
Hi Elaine,
Could you share the download link again for R7000 Firmware 1.0.6.54? I still not able to download by the original link.
Message 5 of 26
ElaineM
@Henrychung828 The link has been updated.
Message 6 of 26
Henrychung828
Thank you @ElaineM. One more question, should I reset to factory setting after load the new firmware or before?
Message 7 of 26
ElaineM
@Henrychung828 Reset it after loading the firmware.
Message 8 of 26
Henrychung828
Thank you @ElaineM
Message 9 of 26
ElaineM
You're welcome @Henrychung828
Message 10 of 26
jbernardo
Apprentice
Hello Elaine,
I'm on V1.0.6.28, do you also recommend a reset to factory defaults after flashing?
Message 11 of 26
ElaineM
@jbernardo Yes, I would factory reset it just to be sure that there are no settings that would cause problems.
Message 12 of 26
spopiela
Guide
Can you backup settings in router, then flash and then pull in the backup cfg settings file.
Message 13 of 26
spopiela
Guide
Does factory reset remove all port forwarding settings?
Message 14 of 26
IrvSp
Master
Not advisable. The data can change between f/w versions. Only reliable when re-flashing the SAME version after you install it and reset. Other case would be if you made changes and didn't like them and wanted to restore the settings you had before changing them. This is especially true if you are going backwards in versions.
However I guess you could try it, but if you have problems, RESET and then manually enter required settings, but it isn't advised to do this.
Message 15 of 26
jbernardo
Apprentice
Thank you. For now I left it running without wiping the settings, but if I have any issue I'll surely follow your advice.
Message 16 of 26
IrvSp
Master
If my memory recall is correct, that was one of the Arlo beta's. If so, people going backwards did complain about an Arlo SSID broadcasting but it didn't work. Seems to have been a remnant of the old beta left. Reseting the router after the backward flash did fix that problem.
Message 17 of 26
spopiela
Guide
Factory Reset
 I'm not sure what settings I changed from factory default. I have at least 8 port forwarding settings that I added. Will those change? Is there a way to get a list of settings that one needs to record befor a factory reset is done.
Message 18 of 26
IrvSp
Master
Re: Factory Reset
Not that I know of? I'd suggest taking SCREENSHOTS of each page and use those as a guide.
Message 19 of 26
spopiela
Guide
Re: Factory Reset
Thank You... great idea!
Message 20 of 26
spopiela
Guide
Re: Factory Reset
Click on Apply button on every page to change setings after factory reset? I am geting along in years, so I hate to keep using up remaining Lifetime .. You have been helpful! A modern household, as I have, with all kinds of home automation, cameras, advanced HAM radio, security systems  and the "plain vanilla" computers has created the most challenging task in electronics... Routers! The R7000 is a great router for me, I struugle to keep up with updates to firmware when a new option arises, like Arlo. The support on Netgear tends to fade away after a new release. Companies need to release firmware in the same way that hardware was released when i was an engineer. Test it, test it and test it some more until everyone is happy. Thank You
Message 21 of 26
spopiela
Guide
Re: Factory Reset
I have OpenVPN also set up on the router. Do any openvpn settings get erased in the router with a factory reset?  It is a pain to set up and I can't really test it from home. It is taking me a lot of time to do R7000 firmware changes when a factory reset is called for.... very painful process.
Message 22 of 26
Hdg
Apprentice
Apprentice
where is the link?
Message 23 of 26
Murdhie
Download it from where?
Message 24 of 26
jguerdat
Guru
Not sure Netgear would appreciate me posting a link to it since the thread has been removed so PM me and I'll send you a Dropbox link for this firmware.
Message 25 of 26
Top Contributors
Discussion stats
  • 25 replies
  • 8386 views
  • 3 kudos
  • 10 in conversation
Announcements
Orbi 770 Series
