- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Does Nighthawk support USB printers for sharing with Mac OS X?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've read a lot of discussions here dating many years back to using the ReadyShare software on a Mac to use a USB printer attached to a Netgear Router, and many discussions saying that ReadyShare software (which doesn't run in current versions of OS X) is obsolete and the printer should just show-up when searching the network for printers... but it doesn't.
... aside: an HP 6MP attached via front USB to the Nighthawk router, router interface shows nothing but USB network storage features... nothing about printers. Mac OS X rev 12.13.
As all discussions about using the Netgear routers for printer sharing are 2015 and earlier, I'm guessing Netgear doesn't support USB networked printers currently in Nighthawk routers?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Does Nighthawk support USB printers for sharing with Mac OS X?
You still have one. I had one of those. Good solid printer.
Ya, not much support anymore for printers on routers.
Your best option would be to find a HP JetDirect box to connect the printer too and connect the JetDirect box to the LAN. Thought you may find it hard to find something that takes parallel or small C connections these days.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
