Orbi WiFi 7 RBE973
Reply
Dynamic QoS grayed out?
TexanEsparza
I'm trying to prioritize certain applications through Qos and disabled AP mode and set up the Qos under advanced settings, but the Dynamic QoS button under the basic tab is still grayed out. Am I missing something or is there another way to prioritize applications?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
Guru
Re: Dynamic QoS grayed out?
What browser are you using? Try IE11, FF or Opera.
Try a factory reset then set up QoS in router mode. QoS only works in router mode. Coming back from AP mode to router mode should be able to use QoS settings after getting back to router mode.
Message 2 of 4
All Replies
Guru
Message 2 of 4
TexanEsparza
changing my browser from chrome to IE11 worked thank you!
Message 3 of 4
Guru
Enjoy. Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 6824 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
